Power Brake Booster
GOOGOODOLL
  • 1996 FORD TAURUS
When removing the brake booster, do you have to bleed the brakes first?
Saturday, July 10th, 2010 AT 3:32 PM
  • 109,896 POSTS
Remove the master cylender from the booster (2 bolts) then remove the booster. There should be no need to bleed the brakes if the only thing being replaced is the booster. The only time you need to bleed the brakes is when hydraulic system has been opened.
Monday, April 5th, 2021 AT 12:07 PM
