Hello
This could be several things. Air in the system will cause erratic gauge readings. A defective radiator cap will too. A defective sending unit, a defective thermostat. If your cooling fans are not properly working, coming on and off, your water pump may not be moving the coolant and your radiator may be clogged.
All assuming you do have plenty of antifreeze in the system………yes?
Not sure when the last time you had the system open for repairs……..but my suggestion would be to first, ensure the system has the correct amount of coolant, no air in the system, ensure the cooling fans are proper working, replace the radiator cap……then change the sending unit, then the thermostat. Do these one at a time to see what makes the difference.
If you need more assistance then please ensure you provide the exact engine by liter and the 8th digit of your VIN.
Aug 25, 2020 at 4:12 AM
(Merged)
