1996 Ford Taurus no heat
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
RON WILD
My heater has suddenly stopped producing heat. Fan works but no temperature control.
Sep 6, 2008 at 3:24 AM
MERLIN2021
  • 17,250 POSTS
Check the hoses going into the heater core, they should both be HOT so be careful, if the outlet pipe is only warm/cold, the heater core is clogged, a common problem in these cars, backflushing may help, but normally replacing the core is the answer.
Sep 6, 2008 at 3:31 AM
