1996 Ford Taurus Need Help
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
VLADIKIEV
I have a 1996 Ford Taurus with a V6 3.0L SOHC engine and wanted to know if it is possible to put a V6 3.0 SOHC Engine out of a 2000 Ford Taurus. Thank you for reading this
May 8, 2009 at 12:44 PM
JGAROFALO
  • 489 POSTS
[quote:ae0d1b3068="vladikiev"]Engine Mechanical problem
1996 Ford Taurus 6 cyl Two Wheel Drive Automatic 98000 miles
I have a 1996 Ford Taurus with a V6 3.0L SOHC engine and wanted to know if it is possible to put a V6 3.0 SOHC Engine out of a 2000 Ford Taurus. Thank you for reading this[/quote:ae0d1b3068]
Should fit just fine as long as it is the same configuration. You will need to use the electronic parts from the 1996 engine to keep the PCM happy.
May 12, 2009 at 5:52 AM
