1996 Ford Taurus need heat for winter
DICKIE DEE
Heater problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
heat will turn to lukewarm air after just under 1 minute. if i turn the switch off for a couple of minutes then back on i get good heat for about a minute then it cools to lukewarm again
Sep 6, 2008 at 3:25 PM
  • 75,988 POSTS
Probable causes: could be thermostat, air mix /mode/ blend doors/vacuum or actuator problems
Sep 6, 2008 at 8:29 PM
