1996 Ford Taurus mai drive pulley
WAYNE SMEALLIE
Engine Mechanical problem
1996 Ford Taurus 6 cyl Front Wheel Drive 154000 miles
drive pulley is free wheeling and does not turn the other critical components. does it have a clutch and how do i fix it. (removal instructiuon)
Dec 1, 2009 at 10:54 AM
BMRFIXIT
  • 19,053 POSTS
Raise and support vehicle. Remove right front wheel assembly. Remove right splash shield. Remove accessory drive belt. Remove crankshaft pulley retaining bolt and washer. Remove crankshaft pulley. Using Crankshaft Damper Remover (T58P-6316-D), remove crankshaft damper from crankshaft.
Dec 2, 2009 at 12:25 PM
