1996 Ford Taurus leaking radiator
135,000 MILES • 6 CYL • FWD • AUTOMATIC
DKUEHN
I have a leaking radiator and a misfiring number one cylinder how much do you think this will cost me to fix in parts and labor
Mar 23, 2008 at 10:44 AM
BMRFIXIT
  • 19,053 POSTS
Misfire and leaking coolant not a good combination
you should have head gasket test done before you go and spend the money on radiator that may blow again
radiator about $300
misfire you need to investigate the cause no price until is clear of the cause
Mar 23, 2008 at 11:31 AM
