1996 Ford Taurus key ignition switch
86,000 MILES • 4 CYL • FWD • AUTOMATIC
KEGRANT
key cylinder is ok and has been removed,and reinstalled, but will not start engine, acts like internal mechanism is 1/2 turn off proper popsition as even when key is in off position(or even when entire key cyl is removed) there is still power to dash pre start lites and acessories such as radio. cannot rotate
mechanism inside steering column with screwdriver. also steering wheel does not lock as is expected
Feb 15, 2009 at 11:31 AM
BMRFIXIT
  • 19,053 POSTS
Suspect a broken rod that connect the key cylinder to the ignition switch
Feb 15, 2009 at 12:15 PM
