1996 Ford Taurus heater fan or switches?
DALE440
Heater problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 180K miles
my heater was working really weak last winter an now it doesnt work at all if i remember right i never had AC i dont know if that matter for this question or not but anyway i was wondering where the heater blower motor is located an if i have to pull the dash out to get to it and how easy it was to change the switches to the heater fan not sure only have changed a couple and i checked all the fuses an they are good so if you can get back to me asap that would be very nice an i will make a donation on the next question i ask i want to see how fast an well you can answer my question so thanks for your time
Dec 9, 2009 at 1:20 AM
  • 75,988 POSTS
Notes Disconnect battery ground cable.
https://images.2carpros.com/forum/automotive_pictures/12900_blower_motor_16.jpg
Pull instrument panel insulator from lower righthand side instrument panel reinforcement. Disconnect blower motor electrical connector. Remove blower motor attaching screws, then the blower motor from A/C evaporator housing. Reverse procedure to install.
Dec 9, 2009 at 2:30 AM
