1996 Ford Taurus Head gaskets
PATTIMAC
  • 1996 FORD TAURUS
Electrical problem
1996 Ford Taurus 4 cyl Front Wheel Drive Automatic
I just bought this car, and now when I turn it on, it is loud, and when I start to drive it there was white smoke coming out of the hood(not alot) then it would stall?
wha't going on and what should I do with it, and how much would you estimated to cost?
Pat
Tuesday, January 27th, 2009 AT 3:14 PM
BILLYMAC
  • 2,204 POSTS
Hi patti, white smoke is a big prob, but not from under the hood if you had white smoke comeing out of exhaust that would be expensive. Sounds like a coolant leak under the hood. Have it pressure tested it will most likely be a radiator or hose or even water pump. But first check the eng oil is it milky or does it look like plain oil //?Check the radiator is there oil mixed with anti? If not have pressure tested this will find the prob. Thanks billymac
Tuesday, January 27th, 2009 AT 9:22 PM
