I replaced My head gasket and the engin is running hot also replace thermostat. its also missing a little
I change spark plugs
Feb 12, 2008 at 11:47 AM
BMRFIXIT
✓Experienced Mechanic
[quote:08562ed6f3="whobbs"]Engine problem
1996 Ford Taurus 6 cyl Two Wheel Drive Automatic 196000 miles
I change spark plugs[/quote:08562ed6f3]
Did you check the heads ?
check water flow throw the radiator
check water pump operation
check head gasket again do the test
Feb 12, 2008 at 11:57 AM
ED ARMES
Water pump failure is typical cause of overheating problems in V-6 taurus. The impellor on the pump corrodes to the point that the blades disentegrate and no longer push coolant. The pump will appear normal on the outside. Have seen this many times. This is also the usual cause for blown head gaskets. :shock:
