1996 Ford Taurus fluid replacment
PAUL VOGT
Transmission problem
1996 Ford Taurus 6 cyl Front Wheel Drive 102245 miles
I was told by a technician that I must replace my tranmission fluid now. The car work well and no problem with the tranmision should I change the fluid in no when shoud I. Thank you for your help.
Paul Vogt
Aug 27, 2010 at 5:55 AM
WRENCHTECH
  • 20,758 POSTS
Transmission fluid is replaced to prevent a problem, not to fix one. Once the trans starts to exhibit symptoms, it's too late for a fluid change and the damage is already done. Manufacturers vary on the recommended intervals. Personally I recommend at least every 60K.
Just be sure to use the correct fluid. Ford requires special fluid, not Dexron.
Aug 27, 2010 at 6:20 AM
