1996 Ford Taurus Erratic Downshifting
124,000 MILES • 6 CYL • FWD • AUTOMATIC
DANINCOLO
After driving 4+ hours at highway speed in 90+ degree weather across Montana, by Taurus suddenly started downshifting into first and then sifting back in to the drive gear. This continued to occur without reason - cruising at 60 mph with no increased load, etc. The transmission has been checked and appears to be fine - but they cannot get the car to duplicate this when they have their scanner hooked up. Now what?
Aug 27, 2008 at 12:22 PM
MERLIN2021
  • 17,250 POSTS
No doubt it's running a bit hot, and this thins the oil, and then it may experience problems related to this Tech bulliten...There is a Tech bulletin on your car for this TSB#98-3-7 Issued on 02/16/1998
Transaxle AX4N intermittent neutral condition, no forward or reverse movement- Vehicles built through 2/1/1998. It's due to the bonded seal on the forward clutch piston intermittently not sealing during a 3-2 downshift.
Remedy: Replace the forward clutch piston with revised part(F8DZ-&A262-AB).
Aug 28, 2008 at 7:33 AM
