1996 Ford Taurus engine skipping
165,595 MILES • 6 CYL • FWD • AUTOMATIC
BLAZIN24
  • 6 POSTS
Could a bad ECM cause the issues I mentioned in my 1st post because I believe the ECM has had issues the whole time I've had the car or would the car cease to run altogether if the ECM went bad I believe the fuel pump and the cooling fans are operated from it but the fuel pump is still working fine so could one part of the ECM stop working properly and one still operate just fine?? Thank you for any input, Mike
Dec 1, 2009 at 4:28 PM
BMRFIXIT
  • 19,053 POSTS
do you have check engine light on ?
and if so need to check for codes
check it for tune up
check fuel pressure
Dec 2, 2009 at 12:21 PM
