1996 Ford Taurus cruise control
BILL49203
  • 15 POSTS
Transmission problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
when i use the cruise control the car shifts eraticly and seem to start off in 3rd gear when i dont have the cruise on the car drives fine What could this be? Also the car seems to not deaccelerate when you take your foot of the gas
Nov 6, 2009 at 7:53 AM
BMRFIXIT
  • 19,053 POSTS
If no check engine light on I would check the IAC
if check engine light on check for codes
Nov 6, 2009 at 10:09 AM
BILL49203
  • 15 POSTS
there is no check engine light, what is the iac? i as told it could b the crusie unit or the crusie not unlocking after turned on, What do you think?
Nov 6, 2009 at 10:45 AM
BMRFIXIT
  • 19,053 POSTS
IAC :Idle air control valve
the cruise should kick out the second you touch the brake paddle
if that isn’t happening check brake switch and cruise control cut off switch
Nov 6, 2009 at 10:49 AM
