Engine Mechanical problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
After having a head gasket replacement done, it now has a miss in the #1 cylinder according to a timing light. It has been put on a borrowed computer and it reads several codes, one being a misfire and some others that haven't been mentioned
what they are. The guy doing the work strongly feels that it needs a new computer. Like I said, it runs with a miss and after running for a little while, it starts backwashing thru the reservoir. It was doing this before the head gasket removal. In your opinion, is ordering a new computer really what it needs? The mechanic says the misfire is causing the overheating which is causing the backwash of the cooling system. Please help!
Jul 31, 2008 at 12:11 PM
