1996 Ford Taurus compression settings
180,000 MILES • 6 CYL • FWD • AUTOMATIC
CRAZYITALIAN71
How many PSI is each cylinder suppose to have to be an accurate reading on a warm engine
Dec 2, 2008 at 6:08 AM
DAVE H
  • 13,383 POSTS
this is for 3.0L .. let me know if your engine is different size ?
ENGINE COMPRESSION
Warm engine to normal operating temperature. Check compression at cranking speed with throttle wide open and all spark plugs removed. Ensure crankcase is at correct level and oil is of correct viscosity. With compression gauge installed, use remote starter to crank engine.
Crank engine 5 revolutions (minimum) and record highest reading. Repeat procedure for all cylinders using approximately same number of revolutions. Lowest compression reading should not be less than 75 percent of highest compression reading. Cylinder compression readings should not be less than 100 psi (7 kg/cm2 ).
COMPRESSION RATIO SPECIFICATIONS
Application....Compression Ratio
3.0L DOHC.......................10.:1
3.0L OHV.........................9.3:1
Dec 2, 2008 at 7:10 AM
