1996 Ford Taurus blown fuse
175,000 MILES • 6 CYL • FWD • AUTOMATIC
LRUTAN
when driving this car and stopping at a stop sign, i push on the accelerator and the car shuts down. i change the ignition fuse and it starts back up again. ignition coil was recently replaced and i thought everything was fine til it happened again today. any ideas?
Sep 14, 2009 at 4:03 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model the Taurus G, GL, LX or SHO and what is your engine size in liter.
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
We need to figure out if it is electrical or fuel related. Pull a plug wire off of the spark plug and insert something into the end of it and have someone try to start the car and have the metal object really close to a piece of metal on the engine and see if you are getting a good strong popping blue spark. Don’t have your hands on any part of the metal!!! If there is no spark, then it is electrical.
If you are getting good spark then spray some starting fluid in the throttle body and try to start it and see if it tries to start then.
You may need to get a fuel pressure check on the fuel pump to ensure it is putting out okay. We will see.
Sep 14, 2009 at 12:02 PM
