Usually a car wont crank because of a bad connection. Even though the cables may look good corrosion builds up inside. Take the cables off and clean them especially the ground. We used to use coke a cola and put that on to clean the terminals, but its better if they are manually cleaned. check the ground for a good connection on the engine.
Dec 4, 2009 at 4:22 AM
