I replaced the battery in the car, which runs great, the red anti theft lite blinks and car wont start
Sep 1, 2010 at 2:09 PM
✓Experienced Mechanic
If the light is flashing, the car won't start. What you need to do is (and I hate to say it) take it to a dealer and have them reprogram the theft system. For some reason, it lost its identification.
Sep 1, 2010 at 2:44 PM
TALLTODDY
MEMBER
Thats not true , i found someone in a forum with the same problem.... if u disconnect both battery leads and let it sit 20 minutes, insert the key in the "on" position, connect the positive post first, then the negative, the car will recognize the key and start...
Sep 2, 2010 at 5:13 AM
Have you tried it?
Sep 2, 2010 at 6:01 AM
TALLTODDY
MEMBER
Yes, i followed those steps and it fired right up... thanks
