1996 Ford Taurus Alternator?
153,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIRDMAN39
The dashboard lights dim and the battery light flashes when I accellerate to about 3000 RPM.No other symptons.Serpentine belt tight and in good shape. Bad alternator?
Thank you
Dec 8, 2009 at 12:11 PM
BMRFIXIT
  • 19,053 POSTS
Remove battery terminals check clean and tighten
check battery volts with engine running it should be above 13.5 V
if not suspect bad alternator
make sure engine has a good ground
Dec 8, 2009 at 12:55 PM
