I noticed the heater does not get very hot. Examination showed the heater core is clean. Realized that the a/c is on whenever the HVAC system is on. The temp selector provides air between ice cold and a little bit warm. It is the same whether the mode is a/c, heat, or vent. It was suggested that the a/c damper door may be the problem, but I'm thinking electrical, since I would think the a/c compressor should not run in vent or heat.
Sep 28, 2010 at 12:41 PM
