1996 Ford Taurus 96 taurus jumpy idle when heater on
175,000 MILES • 6 CYL • FWD • AUTOMATIC
QIKTLN2
hello all-
im new to the site and i own a 96 ford taurus gl. the problem is my idle jumps when the heat or a/c is turned on (when the compressor cycles) i have a cel that pops up with egr fault. my question is would the egr valve most likely be the problem or should i be lookin more at the IAC?
thanks
Oct 11, 2009 at 1:40 PM
JALOPYPAPA
  • 467 POSTS
If you're getting EGR insufficient flow, I'd believe it. If so, the port in the intake manifold probably needs cleaning out. Pretty much have to take the throttle body off to reach it. As for idle, if it's not too high, that might be normal. Most cars automatically increase idle speed to compensate for compressor demand on engine.
Oct 11, 2009 at 4:04 PM
QIKTLN2
thanks for the input. ill have to have the car scanned again to be sure what the code is but the idle is pretty stable except for when the compresor kicks in, the car actually will surge forward and almost pull through the brakes while at a stop light for instance. and while at a steady speed like driving on the highway i can feel the engine surge
Oct 12, 2009 at 12:48 AM
JALOPYPAPA
  • 467 POSTS
OK, if that's the case, maybe you're on the right track with the IAC, but you need the code too.
Oct 12, 2009 at 10:00 PM
QIKTLN2
ok thanks! i will post my findings and what fixed the problem as soon as i find out
Oct 13, 2009 at 12:44 AM
