1996 Ford Taurus SHO Engine Swap
A
hello i have a 1996 ford taurus gl and i was wondering if i could put the sho engine in it without having to change the transmission or wiring
May 26, 2006 at 10:38 AM
LOSONE
  • 1,616 POSTS
You can do it but is will require a major, expensive operation including wiring and computer. I would guess about 4K should do it.
May 26, 2006 at 10:51 AM
A
nope wont do that i will just put the original engine back in it and just buy a SHO taurus if i want that kind of power
thanks for the help anyways
adam
May 29, 2006 at 3:32 PM
Suggested Repair
A SHO engine swap is not a simple drop-in and requires a major, expensive conversion including wiring and computer changes. Reinstall the original engine rather than attempting the swap.
Conversation Summary
The owner of a 1996 Ford Taurus GL asked whether a SHO engine could be installed without changing the transmission or wiring. The expert said the swap is possible but requires a major, expensive operation including wiring and computer work, estimated around $4,000. The owner decided against it and planned to reinstall the original engine.
