HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Symptoms
Stall While Driving
SPONSORED LINKS
1996 Ford Taurus
JEFF EISNER
MEMBER
1996 FORD TAURUS
Other Category problem
1996 Ford Taurus Engine Size unknown Two Wheel Drive Automatic 140, 00 miles
The car will start but when you put it in to gear it will die. What could the problem be?
Sunday, January 6th, 2008 AT 9:18 AM
BMRFIXIT
MECHANIC
Check and clean idle air valve
or replace it
neutral safety switch need adjusting
SPONSORED LINKS
Monday, January 7th, 2008 AT 12:56 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
1996 Taurus Stalling
Have A 1996 Ford Taurus, The Service Endine Lite Came On So I Ran A Scan Tool Over It And It Says Both Banks Are Running To Lean, The...
Asked by
liberteenme
1996
FORD TAURUS
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
96 Taurus Stalling
My 96 Ford Taurus Started Stalling, I Took It To Get The Code Checked When The Check Engine Light Came On, They Told Me To Replace The...
Asked by
taurusgirl85
1 ANSWER
1 IMAGE
1996
FORD TAURUS
1996 Ford Taurus Bat S- Crazy Electrical (?) Problems...
My Battery Light Came On The Other Day, So We Replaced A Cracked Cable. That Didn't Do The Trick. I Drove It The Next Day And The Light...
Asked by
anchovie19
1 ANSWER
1996
FORD TAURUS
1996 Ford Taurus Engine Barely Idles
My 96 Taurus Blew A Freeze Plug While Driving On A Divided Highway. I Heard A Ticking Noise, The Rpm's Started To Go Up, Speed Went Down...
Asked by
return2beach
1996
FORD TAURUS
Cuts Out When Accelerating
Engine Cuts Out When Accelerating Uphill And Transmission Downshifts At Approx. 3000 - 3500 Rpm. Car Violently Jerks Back And Forth As...
Asked by
VuAll.com
1 ANSWER
2003
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear
Code Read Retrieval/Clear Mercedes-Benz C230
How to Read Trouble Codes
Online car repair manuals
