1995 Ford Taurus will not start
123,000 MILES • 6 CYL • FWD • AUTOMATIC
SPORTSTERMAN80
  • 5 POSTS
i have a 95 taurus that will not crank at all the key turns and i get a click from the starter relay and then nothing i have had the starter tested and passed 2 times i replace the ignition switch and no avail just looking for any other cause the battery tests fine and all cables are clean and good connection thaqnk you for your help
Jan 8, 2010 at 11:22 AM
  • 75,988 POSTS
Jump start the starter at the starter relay and let me know, if it cranks over -check the transmission range switch
Jan 8, 2010 at 11:25 AM
SPORTSTERMAN80
  • 5 POSTS
how would i in about jumping the starter at if relay i know the relay clicks when i try to start but thats all that happens thanks
Jan 8, 2010 at 8:12 PM
  • 75,988 POSTS
If you put a screwdriver across the battery and S terminal this would cause the starter to crank engine over if full battery voltage coming out the other side of the relay -if so the starter is defective
Jan 9, 2010 at 8:18 AM
