1995 Ford Taurus when cold, engine stalls when selecting re
102,000 MILES • 6 CYL • FWD • AUTOMATIC
GPK3007A
When the car is cold it stalls when put in reverse, reverse is unuseable until the car is up to operating temp. even if I rev the engine while trying to slam it into reverse it just stalls. As long as I shift quickly into drive I can at least go forward, but it is a pain always looking for a parking spot where I wont need reverse.
Dec 7, 2008 at 3:58 AM
BMRFIXIT
  • 19,053 POSTS
check for vacuum leaks (intake gasket and pcv valve ,hoses)
check idle air control valve (clean or replace )
Dec 7, 2008 at 10:22 PM
GPK3007A
[quote:0b92f806a2="BMRFIXIT"]check for vacuum leaks (intake gasket and pcv valve ,hoses)
check idle air control valve (clean or replace )[/quote:0b92f806a2] thanks alot, it was the idle air cntr.valve, i greatly appriciate your help, greg
Dec 9, 2008 at 6:39 AM
