1995 Ford Taurus Water Temperature
70,000 MILES • 6 CYL • FWD • AUTOMATIC
CRESSY9
Dear Carpros,
Recently, when I drive my taurus, the water temperature gauge is fluctuating erradicly, when i step on the gas it goes up, and when I am coasting it goes right down. Is this the water pump or maybe the thermostat?
Thanks, matt
Oct 21, 2008 at 4:22 AM
RENAUDTN
  • 636 POSTS
It is possible your thermostat or your water pump are not working right, but it actually sounds like your cooling system is a little clogged (when was the last time you serviced it?).
Have your cooling system flushed and cleaned and refilled with new coolant. Since your car seems to have overheated a little bit, I would also put a new thermostat just in case.
If this doesn't fix your problem, reply back and we'll look at other possibilities.
Oct 22, 2008 at 3:18 AM
