Ford dealership said it was the Vehicle Speed Sensor and Speed Sensor Gear
136,000 MILES • 6 CYL • FWD • AUTOMATIC
SMITTYD
My speedometer was going crazy. The Ford dealership said it was the Vehicle Speed Sensor and Speed Sensor Gear. Is this two different parts or all-in-one piece? Can someone give steps on how to change this? Thanks...
Jan 28, 2008 at 5:45 AM
SQM
  • 6,383 POSTS
The vehicle speed sensor (VSS) is located on the transmission housing (see diagram below).
The VSS consists of a built-in gear, comes as a unit.
Replacement of the VSS is straight forward. You will have to remove the speedometer cable and the mounting bolt to remove the VSS.
Oct 20, 2021 at 7:38 AM
