1995 Ford Taurus Veh won't trun off with key.
155,000 MILES • 6 CYL • FWD • AUTOMATIC
SHANNARALLERS
The key does not turn off my vehicle. I had the small box pulled out and re-alligned the metal switch so my key will start the car, but it won' t let me turn it off so we wrapped a wired coat hangar around the metal switch on top to pull when I need to turn off the car. In order to fix this problem will I need to replace the whole steering column or is simpler than that?
Feb 28, 2008 at 10:51 AM
BMRFIXIT
  • 19,053 POSTS
its not an easy job specially if you have tilt wheel
it may be easier for you to replace the steering column
good luck
Feb 28, 2008 at 2:01 PM
