The transmission started leaking a lot of fluid so I took it to the shop to have the seal replaced. The shop said the transmission had run hot and was in need of rebuilding. The wanted 1,500.00 to do the work. I did not want to spend that musch due to the car being so old. However I found a 97 Tarus with the same size engine but the motor is blown. I can buy the car for 200.00. Question is, will that year transmission fit the car I have?
Thanks
Kenny
Thanks
Kenny
Apr 3, 2009 at 1:35 AM
