If it is only leaking out when you start the vehicle then it sounds like a front pump seal. The tranny will have to come out to repair.
If it is leaking whether the vehicle is running or not the it could possibly be the Axle seal at the tranny on the driver side.
It is also possible that the transmission pan gasket is leaking.
You would have to try to get up under the vehicle to get a good look and see if you can tell exactly were it is leaking.
Tuesday, April 13th, 2021 AT 8:06 PM
