1995 Ford Taurus Timing chain
JESSIE DUNN
Engine Mechanical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic
I have been trying to set the timing on my 95 ford taurus. but all it does is cranks. this is a new timing chain and we put it on the compression stroke but it still won't start any ideas on what might be wrong?
Sep 23, 2008 at 11:14 AM
BMRFIXIT
  • 19,053 POSTS
what do u have for engine size
do a compression test
check for spark
check for fuel pressure
check injector pulse
recheck your work make sure you have not set it at 180 off
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 23, 2008 at 2:48 PM
