1995 Ford Taurus tensioner bellt pully
PRECIOUS1ONE
Noises problem
1995 Ford Taurus Front Wheel Drive Automatic
Hi i have the belt off the car but i don't know which way to loosen the nut. to change the pully.when i go to the right it swings the tensioner so i don't know to go left or right. please help
Sep 11, 2010 at 1:24 PM
  • 110,248 POSTS
To loosten the nut, turn it counter clockwise.
Sep 13, 2010 at 4:22 AM
YOUKNOWMYNAME67
  • 25 POSTS
if you are turning the nut and its moving the tensioner you are on the wrong nut.... the tensioner pulley has a nut through it but you will notice it is part of a houseing there is another bolt that holds this to the block and that is the bolt you need to loosen. (counter clockwise)
Sep 17, 2010 at 11:15 AM
  • 110,248 POSTS
It's me again. In your original post, you mentioned that you are replacing the pulley. The last post was regarding the tensionier removal. What the person said is correct; however, that is if you are replacing the entire tensionier and not just the pulley. Let me know which it is so I can guide you.
Sep 17, 2010 at 3:29 PM
