How do you replace the front sway bar? Also, why does the airbag light blink the code 12 ?
Dec 30, 2007 at 10:44 AM
TAURUSWHEEL
✓ASE Certified Mechanic
For stabilizer bar, you have to remove the end links, drop the rear of the subframe down to remove brackets, etc.. if you don't have proper equipment, don't attempt.. why do you ned to remove it??/ Airbag 12 is low battery voltage
Dec 31, 2007 at 12:59 AM
