my 95 taurus gl wouldn't start. it just clicked when i turned key. i tried to jump start. same result. my battery tested at 12.85 volts. the starter was tested and deemed faulty. i replaced it. same result. only this time, the positive and negative cables at the battery got very warm. i tested continuity on both + and - cables. checked out good. i checked all connections concerning the grounds. all connections solid and in place. my alternator is good. same with ignition switch. i removed new starter and it tested good. solenoid, too. all fuses, under dash and hood, are good. please help! i'm stumped and it's my only transportation to see my 3 1/2 yr. old daughter. we miss each other tremendously!
Mar 15, 2008 at 8:32 PM
