1995 Ford Taurus stalling
125,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBSR4132
the car stalls every time i drive it, never did it before only recently been happening
Aug 22, 2010 at 2:13 AM
  • 75,988 POSTS
Next time it stalls do below to determine if it's fuel or spark issue,don't wait for nothing-do immediately:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 26, 2010 at 3:28 PM
