1995 Ford Taurus spark/fuel
C.THOM1
Engine Mechanical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic
have done compression test and fireing order is correct just will not fire have done timing checks to and its all right.
Feb 13, 2010 at 7:20 AM
BMRFIXIT
  • 19,053 POSTS
Do you have spark
Do you have fuel and fuel pressure?
Did you check the fuel if contaminated
Do you have injector pulse?
When key on do you have check engine light on
Feb 14, 2010 at 1:26 PM
