1995 Ford Taurus running hot
157,286 MILES • 6 CYL • FWD • AUTOMATIC
AMCCLAIN
my car is running hot, i took it to my mechanic, he change the thermostat, and replace the coolant jug cap, he check the water pump and it is pumping fine, but my car is still running hot. my mechanic don't even know what might be causing it to run hot. i don't know what else to do, i am running hot, because we can't figure out what is going on. the cooling fan is working.
Jun 14, 2008 at 5:28 AM
MERLIN2021
  • 17,250 POSTS
Try cleaning out the radiator fins with compressed air, you may be clogged, when was the last radiator flush and fill?
Jun 14, 2008 at 5:37 AM
