turn signals not working?
200,000 MILES • 6 CYL • FWD • AUTOMATIC
WFULLER
rear signal lights do not work...have tried replacing bulb. the tail lights do work. noticed mouse poop the other day under front passenger floor mat and on engine when adding oil. do you think that they may have chewed wires and if so why do all of the other lights work?
Jan 27, 2008 at 6:39 AM
BMRFIXIT
  • 19,053 POSTS
when step on brake do you have brake light in the back if so the bulbs are OK and you should check the flasher? This guide can help fix it
https://www.2carpros.com/articles/turn-signals-not-working-blinker
let us know
Jan 27, 2008 at 6:45 AM
WFULLER
[quote:64e574e46b="BMRFIXIT"][quote:64e574e46b="wfuller"]Electrical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic 200000 miles
rear signal lights do not work...have tried replacing bulb. the tail lights do work. noticed mouse poop the other day under front passenger floor mat and on engine when adding oil. do you think that they may have chewed wires and if so why do all of the other lights work?[/quote:64e574e46b]
if so the bulbs are OK and you should check the flasher[/quote:64e574e46b]
the break lights do not work and the one on the hatch only half comes on
Jan 27, 2008 at 7:12 AM
WFULLER
we have checked all fuses and bulbs still nothing including flashers.
Jan 27, 2008 at 7:57 AM
BMRFIXIT
  • 19,053 POSTS
What I found a common thing with that is the combo switch
Jan 27, 2008 at 8:35 AM
RAYCULL1
my turn signals quit working and I've replaced the flashers already. not sure why they still wont work.
Dec 2, 2020 at 12:48 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Need to inspect multi-function (turn signal) switch. Ensure there are now broken wires and also test for power at the switch. If power is there and wires are OK suspect faulty switch.
Thanks for using 2CarPros.com !
DRAGONFLY1
While trying to install radio in my Taurus, 3 fuses where blown - after replacing the blown fuses & checking the rest I started the car & the left turn signal is flashing (fast like it does when the bulb goes out), the left signal wont work at all, AND it wont stop either! I actually had to remove the bulb from the housing because it has almost caused accidents obviously because people think Im turning left when Im not..The bulbs are ok, no fuses are blown..I am not understanding why the indicator continues to flash as though its stuck almost..I am completely frustrated so any help would be appreciated!
Dec 2, 2020 at 12:49 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Sounds like a broken turn signal switch. Does the right signal work ok? bulbs flash front and rear on the left side?
DRAGONFLY1
No, the right turn signal does not work at all - its completely dead compared to the left one that wont STOP flashing (I had to remove the left bulb in front & back - I should also mention that the left indicator on the inside of the car continues to flash!).
And the answer to your next question is yes, the bulbs flash front & rear on the left side (obviously not now since I have removed both front & rear bulbs on the left side).
You mentioned a broken turn signal switch - I should also let you know that we just replaced that not even 3 weeks prior to this incident w/ the signals..it was the "Combination Switch" to be exact, & it wasnt because the turn signals werent working, it was because the windshield wipers had stopped working.
I was wondering if its possible that we could have damaged that new switch somehow when we were trying to install the radio & ended up blowing those 3 fuses because the turn signals worked just fine right before we blew those fuses..do you think we could've damaged the entire switch?..
Someone also said something to me about the "flasher" or the "turn signal relay"..but I have no idea where those things are even located in the car much less what they are...
2CARPRO JACK
  • 11,533 POSTS
Sounds like you may be onto something.If all worked prior to installing the combo switch, I think you may have a pinched wire or the such. Take the plastic covers back off and inspect all the wiring.
BRUCE JEAN
  • 7 POSTS
I checked all fuses, under dash and under hood. The car does not have round flasher in fuse box, and could not locate one under dash. It has three small breakers in fuse box, and all three have power going through them. Stumped. Any help would be great. Thanks.
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
The flasher is located above the fuse box. I have attached a few pictures and it is labeled as #18. This does sound like a flasher problem. I have also attached a few tutorials for you to view. Hope this helps and feel free to as any questions.Thanks for using 2CarPros.
Danny-
BRUCE JEAN
  • 7 POSTS
Okay, thanks Danny. I am on the road and will not be able to work on it until Saturday, but I will defiantly let you know how it goes. Thanks again, talk to you Saturday.
  • 55,549 POSTS
Please let us know how it goes.
BIG DADDY ONE
Electrical problem
1992 Ford Taurus 6 cyl Front Wheel Drive Automatic 100 k miles
replaced turn signal indicator under the dash and the multi functional switch on the steering column.
and i still do not have turn signals. if i pull the handle down a little the turn signals will light up but not flash.
the rear defroster also is not working, could this be a ground. any suggestions would be great
BLUELIGHTNIN6
  • 16,542 POSTS
so when trying to activate the turn signals they will come on solid but not blink? what happens when the hazard button is turned on, do the lights flash then or still just solid?
BIG DADDY ONE
no they won't do anything they won't blink the only thing that comes on is the road indicator light the bright light on the left and right of the car, it's been very confusing and usually i am pretty Good at finding the problem
BLUELIGHTNIN6
  • 16,542 POSTS
did rear defroster stop at same time as this issue occured? have you checked all fuses?
BIG DADDY ONE
yes we checked the fuses and the emergency flashers work
BLUELIGHTNIN6
  • 16,542 POSTS
seems like you have wiring issue in the steering column where the multi function switch attaches. will need to open up the column and inspect the wiring to ensure nothing is loose or damaged.
DRKORAF
The hazzard lights and turn signal lights on my 1995 Ford Taurus GL wagon, 3.0 L w/101,00 miles suddenly stopped working. All interior and exterior light bulbs and fuses are good and hi/low headlights, parking lights work fine HOWEVER only the top rear/middle cargo hatch LED brake light works, the two main rear brake lights/turn signals do not work even though bulbs are good. All other electrical systems appear to be working fine including horn, heater,AC,radio,alternator, wipers, cruise control,defroster, lighter, etc.
What is causing the problem and what/where is the fix? Is it the brake light switch and would it have to be replaced (can I do it?) or is there a breaker somewhere I can reset?
2CARPRO JACK
  • 11,533 POSTS
If all fuses are good then you need to test for power through the brake light switch.If brake and turn arent working it sounds more like the turn signal switch is the problem
  • 75,988 POSTS
No hazards-could be the flasher, for the brake lites maybe from the brake switch to the bulb socket an open circuit
Do what Mr.Jack recommended
