1995 Ford Taurus oxygen sensor
106,000 MILES • 6 CYL • FWD • AUTOMATIC
TBUCSFAN56
  • 6 POSTS
I understand there are two of them. Does anyone know where they are located? I figure if I replace one I may as well replace the other.
May 2, 2008 at 12:18 PM
BMRFIXIT
  • 19,053 POSTS
on the exhaust system before and after the catalytic converter
May 2, 2008 at 2:25 PM
TAURUSWHEEL
  • 718 POSTS
why are you replacing them, are there codes to tell you there's a problem??? If not, don't waste your money. Save it for gas... when the o2 sensors exceed parameters or there is another issue involving them, the light will come on..
May 4, 2008 at 1:52 PM
TBUCSFAN56
  • 6 POSTS
[quote:f8283d0cc9="TaurusWheel"]why are you replacing them, are there codes to tell you there's a problem??? If not, don't waste your money. Save it for gas... when the o2 sensors exceed parameters or there is another issue involving them, the light will come on..[/quote:f8283d0cc9]
My daughter took it in to a shop because the check engine light came on and they read the code which pointed to the oxy sensors. Prior to this the car was running a little on the crappy side. We replaced them and it is running much better. If you have another angle I am open to any help. I would like to thank everyone for their help on this board.
May 4, 2008 at 10:27 PM
TAURUSWHEEL
  • 718 POSTS
So you replaced both sensors??? Unusual for both to fail. Some codes indicate lean or rich switching issues which are not directly caused by the o2 sensors, but by another component.
May 5, 2008 at 8:59 AM
TBUCSFAN56
  • 6 POSTS
[quote:815ce4095c="TaurusWheel"]So you replaced both sensors??? Unusual for both to fail. Some codes indicate lean or rich switching issues which are not directly caused by the o2 sensors, but by another component.[/quote:815ce4095c]
Yes, Both, they were original parts and I had no way of testing them. Wastiful? Yes. If this maybe another component I am open to what this maybe. Thanks in advanced. I really appreciate your help!
May 5, 2008 at 11:34 AM
BMRFIXIT
  • 19,053 POSTS
[quote:3552a3f174="TaurusWheel"]So you replaced both sensors??? Unusual for both to fail. Some codes indicate lean or rich switching issues which are not directly caused by the o2 sensors, but by another component.[/quote:3552a3f174]
I agree
codes will help
but if the o2 sensor indicating running lean or rich that’s mean you have a vacuum leak or some other issue going on
and it need to be checked
check for an exhaust leak before the o2 sensors
I would start by checking for vacuum leaks
check the basic 1st
good luck
May 5, 2008 at 12:41 PM
