[quote:3552a3f174="TaurusWheel"]So you replaced both sensors??? Unusual for both to fail. Some codes indicate lean or rich switching issues which are not directly caused by the o2 sensors, but by another component.[/quote:3552a3f174]
I agree
codes will help
but if the o2 sensor indicating running lean or rich that’s mean you have a vacuum leak or some other issue going on
and it need to be checked
check for an exhaust leak before the o2 sensors
I would start by checking for vacuum leaks
check the basic 1st
good luck
May 5, 2008 at 12:41 PM
