1995 Ford Taurus O2 sensor
102,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMK1
Is the O2 sensor on the catalytic converter or is it separate on the exhaust system? How far is the O2 sensor from the cat. con. if they are separated?
Thank you -- Jim K.
Sep 23, 2008 at 6:33 PM
BMRFIXIT
  • 19,053 POSTS
6CYL YOU HAVE 4 O2 SENSORS
bank 1 sensor one before the cat on #1 cylinder side
bank 1 sensor two after the catalytic converter on # 1 cylinder side
bank 2 sensor one before the catalytic converter on the other side of the engine cylinders # 4,5,6
bank 2 sensor two after the catalytic converter
Sep 23, 2008 at 10:56 PM
