1995 Ford Taurus no start
99,000 MILES • 6 CYL • FWD • AUTOMATIC
WAHOOKA
will not start most of the time when it does start runs fine for ten seconds then check engine light and stalls wioll not restart till next am
when it wont start it will not eec test
cooling fan stays on and fuel pump runs continous
if i get it to start am cold and i run the rpm up to around 1800 i can keeep it running for a couple minutes then bang check engine ligt and stall
Nov 23, 2009 at 8:24 AM
BMRFIXIT
  • 19,053 POSTS
Suspect constant control relay module (CCRM)
a faults in CCRM should set a diagnostic trouble code
Nov 23, 2009 at 12:49 PM
WAHOOKA
i fixed open circuit blue w/ orange stripe wire
no codes 512 kam gone
same intermittent stall no start cooling fan stays on
is there a resistor wire to ignition coil
Dec 4, 2009 at 11:54 PM
