WE ALREADY REPLACED THE BRAIN THE FUEL PUMP, THE FUEL FILTER, BODY CONTROL MODULE, IGNITION CONTROL MODULE, AND CHECKED ALL THE FUSES ANDTHEY WERE FINE. CAR WAS RUNNING THEN JUST QUIT. TESTED FUEL PUMP WITH AN ACCESSORY HOT WIRE AND THE FUEL PUMP WORKED BUT UNDER NORMAL OPERATION FUEL DOES NOT REACH THE INJECTORS
Feb 10, 2010 at 6:57 AM
