1995 Ford Taurus NO FUEL GETTING TO FUEL RAIL
226,000 MILES • 6 CYL • FWD • AUTOMATIC
MURPHYS03
WE ALREADY REPLACED THE BRAIN THE FUEL PUMP, THE FUEL FILTER, BODY CONTROL MODULE, IGNITION CONTROL MODULE, AND CHECKED ALL THE FUSES ANDTHEY WERE FINE. CAR WAS RUNNING THEN JUST QUIT. TESTED FUEL PUMP WITH AN ACCESSORY HOT WIRE AND THE FUEL PUMP WORKED BUT UNDER NORMAL OPERATION FUEL DOES NOT REACH THE INJECTORS
Feb 10, 2010 at 6:57 AM
BMRFIXIT
  • 19,053 POSTS
Was the constant control relay module checked or replaced
Check it for good ground
Located by the battery and on the radiator
Feb 11, 2010 at 12:27 PM
