1995 Ford Taurus Leaking Hose
88,000 MILES • 6 CYL • FWD • AUTOMATIC
NICALOVE85
The hose that goes into the water pump is leaking. I need to know how to take off that metal clamp around the end of the hose. Please help.
May 8, 2008 at 10:08 AM
  • 31,937 POSTS
Hi there,
As there are a few different methods of fixing hoses, i will give you a few options, so it its not these let me know.
Screw clamps, use a screw driver
Spring type, Pliers or the special removal tool.
band clamp, often need to be squeezed to release or the end dislodge with a small screwdriver.
capped, screw type with an anti tamper cap.. flick of cap to access screw head.
See how you go.
Mark (mhpautos)
May 8, 2008 at 12:12 PM
