It keeps shutting off after I start it!It sound like it is shutting off the fuel to the engine????Can you help me???
Jul 2, 2010 at 9:59 PM
✓Experienced Mechanic
Check the fuel pressure if its within specs if okay-clean out the idle air control valve and EGR/PCV valves and test the throttle position sensor and also clean the MAF sensor with an approved cleaner
