1995 Ford Taurus Interior lights
ALSTEVENS
  • 1995 FORD TAURUS
Electrical problem
1995 Ford Taurus 6 cyl Two Wheel Drive Automatic
My interior door and dome lights will not turn off, unless I remove the fuse which also works my stero. Can this be a door switch or relay. Can you please help. Breezewayal@shaw. Ca
Sunday, February 8th, 2009 AT 3:42 PM
BMRFIXIT
  • 19,053 POSTS
Most likely it the door switch
try and use WD 40 and spray in the door latch and in it
close and open the door few times hoping to loosen it and get it to work again
if not need to remove door panel and replace
check dome light switch if all the way up will do the same
Monday, February 9th, 2009 AT 6:07 PM
