1995 Ford Taurus Ignition Switch
174,000 MILES • 6 CYL • FWD • AUTOMATIC
6X6TREX
I need a wiring diagram for the ignition switch. I am building a dune buggy and am going to replace the ignition switch with this one.
[img:21438a1b18]http://www.2carpros.com/forum/automotive_pictures/272456_switch_1.jpg[/img:21438a1b18]
Nov 16, 2008 at 4:38 PM
  • 75,988 POSTS
Find the battery feed wire going to the switch-hook that up to the center terminal now hold key in starting position check for power at the two other terminals the one that has power while key at cranking position put the wire that's coming from the starter to this terminal the other terminal is for the ignition circuit-
Good Luck
Nov 16, 2008 at 4:53 PM
